はじめに
Whether you have a faulty battery, or would simply like to carry around a few extra for an extended outing, this guide will show you how to switch them out.
必要な工具と部品
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
5 の人々がこのガイドを完成させました。
コメント 1 件
amigos saludos cordiales.
tengo un problema con mi canon t5 vi que le rompio o desprendio un pin de la parte de donde labateria encaja dentro de la camara la idea es como conectarla o soldarla? o repararla ls agradesco su atencion.
