はじめに
Replacing the motherboard is a last resort for correcting water damage to the camera. This guide will help you remove it step-by-step.
必要な工具と部品
Remove four 3 mm Phillips #000 screws on the bottom of the camera.
I’m using the 000 screwdriver but the screws won’t come lose. Does anyone have a solution?
Detach the blue cable by sliding the pointed end of a spudger between the motherboard and the silver prongs connected to the cable.
With tweezers, pinch the ends of the remaining orange ribbon cables, and gently pull these ends off of the motherboard.
Sometimes it’s easier to use a spudger to lift the plastic rails holding the cables in place, and using the edges of the cable and the pointed end of the spudger to push them out.
19 の人々がこのガイドを完成させました。
7 件のコメント
There was one huge step left out. On the T3i there is a fiber optic cable connection on the underside, top right hand side of the motherboard. If you don't reconnect this before reassembly your camera won't work. It is difficult to make sure both this cable and the adjacent white round-wire cable are connected before putting the motherboard back in place.
How do you connect it?
I concur with Albert Einstein. It was very difficult. This should be mentioned int the steps, not reserved for the comments!
Yes, 15 step. to make it easier to connect the optical cable and the second rear cable is better to remove the top cover
I want to know a camera repair shop where I can send my Canon Rebel T3i.
Will you please get back to me as soon as possible!!!
