メインコンテンツにスキップ
Canon EOS Rebel G Back Panel Replacement
必要な工具と部品
  1. Canon EOS Rebel G Back Panel Replacement, Front Panel: 手順 1、 1の画像 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Replacement: 手順 2、 2の画像 1 Canon EOS Rebel G Back Panel Replacement: 手順 2、 2の画像 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Replacement: 手順 3、 3の画像 1 Canon EOS Rebel G Back Panel Replacement: 手順 3、 3の画像 2 Canon EOS Rebel G Back Panel Replacement: 手順 3、 3の画像 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Replacement, Top Panel: 手順 4、 1の画像 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Back Panel Replacement: 手順 5、 1の画像 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Back Panel Replacement: 手順 6、 1の画像 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Back Panel Replacement: 手順 7、 3の画像 1 Canon EOS Rebel G Back Panel Replacement: 手順 7、 3の画像 2 Canon EOS Rebel G Back Panel Replacement: 手順 7、 3の画像 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Back Panel Replacement, Back Panel: 手順 8、 1の画像 1
    • Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
    • Remove the strap anchor.
  9. Canon EOS Rebel G Back Panel Replacement: 手順 9、 1の画像 1
    • Unlatch the back panel.
    • Using a #00 Phillips screw driver, unscrew the six screws on the bottom of the camera.
    • One 7.4 mm Phillips screw
    • Two 6.0 mm Phillips screws
    • Two 4.4 mm Phillips screws
    • One 3.9 mm Phillips screw
  10. Canon EOS Rebel G Back Panel Replacement: 手順 10、 3の画像 1 Canon EOS Rebel G Back Panel Replacement: 手順 10、 3の画像 2 Canon EOS Rebel G Back Panel Replacement: 手順 10、 3の画像 3
    • From the bottom of the camera push the hinge rod in with your finger.
    • Return the camera to its upright position.
    • Use pliers (or tweezers) to pull the rod out from the top.
終わりに
作成者
7人の作成者と共同で作成されました。
Zach
メンバー登録日: 04/04/12
43 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S14G9
5 メンバー
36のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 22
今までの合計 1,891
