はじめに
Many times when it seems as if your LCD screen is cracked, it is just the plastic protector, not the actual screen. It is a simple and cheap piece to replace.
必要な工具と部品
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Use a soft cloth to push up on the LCD plastic protector from underneath the top of the camera.
終わりに
