メインコンテンツにスキップ
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
必要な工具と部品
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 手順 1、 3の画像 1 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 手順 1、 3の画像 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: 手順 1、 3の画像 3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 2、 2の画像 1 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 2、 2の画像 2
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 3、 2の画像 1 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 3、 2の画像 2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 4、 2の画像 1 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 4、 2の画像 2
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 5、 3の画像 1 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 5、 3の画像 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: 手順 5、 3の画像 3
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Paul
メンバー登録日: 03/12/18
792 ポイント
3のガイドは作成済み
チーム
University of Memphis, Team S2-G5, Kim Spring 2018 University of Memphis, Team S2-G5, Kim Spring 2018人のメンバー
UM-KIM-S18S2G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 2,347
