メインコンテンツにスキップ
Canon EOS 70D Back Cover Replacement
必要な工具と部品
  1. Canon EOS 70D Back Cover Replacement, Interface Cover: 手順 1、 2の画像 1 Canon EOS 70D Back Cover Replacement, Interface Cover: 手順 1、 2の画像 2
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon EOS 70D Back Cover Replacement: 手順 2、 3の画像 1 Canon EOS 70D Back Cover Replacement: 手順 2、 3の画像 2 Canon EOS 70D Back Cover Replacement: 手順 2、 3の画像 3
    • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
    • Underneath where the rubber grip was, remove the following screws:
    • Three M1.7x5.5mm Phillips #000 screws
    • Pry off the plastic interface cover.
    • Use a plastic opening tool if a fingernail doesn't work.
  3. Canon EOS 70D Back Cover Replacement, Back Cover: 手順 3、 3の画像 1 Canon EOS 70D Back Cover Replacement, Back Cover: 手順 3、 3の画像 2 Canon EOS 70D Back Cover Replacement, Back Cover: 手順 3、 3の画像 3
    • Using the plastic spudger tool, peel back the rubber grip on the right side of the camera to expose the screws.
    • Remove the following screws underneath the right rubber grip:
    • One M1.7x3.0mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
    • On the back of the camera, remove the following screws:
    • Two M1.7x5.5mm JIS #000 screws
  4. Canon EOS 70D Back Cover Replacement: 手順 4、 3の画像 1 Canon EOS 70D Back Cover Replacement: 手順 4、 3の画像 2 Canon EOS 70D Back Cover Replacement: 手順 4、 3の画像 3
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x3.0mm JIS #000 screws
    • Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
    • Be very careful when lifting the back cover up, there are still two fragile cables attached to it.
    • You can lift the back cover towards the bottom of the camera to get better access to remove the cables.
  5. Canon EOS 70D Back Cover Replacement: 手順 5、 3の画像 1 Canon EOS 70D Back Cover Replacement: 手順 5、 3の画像 2 Canon EOS 70D Back Cover Replacement: 手順 5、 3の画像 3
    • With a plastic spudger tool, gently lift up on the black locking tab on the ribbon cable connector.
    • Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
    • Use the plastic spudger to gently pry off the other cable connecting the back cover to the camera.
    • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
    • With both of the cables disconnected, you can finish lifting off the back cover from the camera.
終わりに
添付文書
作成者
1人の作成者と共同作成されました。
Zephosk
メンバー登録日: 09/26/24
5,457 ポイント
34のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 130
