メインコンテンツにスキップ
Canon EOS 60D Rear LCD screen protective plastic cover Replacement
必要な工具と部品
  1. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen Dissasembly: 手順 1、 1の画像 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
    The screws (in orange) near the swivel base are shorter, 2.5mm. Also do not remove the screws (in red) on either side of the screen, it is unnecessary for removing the rear cover. See my comment on the next step.
    rakurai - 返信
    The first 4 steps aren’t necessary
    Dave Common - 返信
  2. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
    Absolutely unnecessary for removing the rear cover. Instead, remove the small plastic piece at the swivel base that was held by two 2.5mm screws (see previous step) and continue with the guide.
    rakurai - 返信
  3. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 3、 2の画像 1 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 3、 2の画像 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 4、 1の画像 1
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
    Faut il tirer dessus vers l exterieur ou vers le haut
    karim B - 返信
  5. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen: 手順 5、 2の画像 1 Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD Screen: 手順 5、 2の画像 2
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 6、 1の画像 1
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
  7. Canon EOS 60D Rear LCD screen protective plastic cover Replacement, Rear LCD screen protective plastic cover: 手順 7、 1の画像 1
    • Slowly insert the tip of the Jimmy between the damaged plastic cover and the plastic frame, which holds it, to loosen the connection between them.
    • The Jimmy is sharp, so take special care when using it to avoid damaging the plastic frame or causing personal injury.
  8. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 8、 2の画像 1 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 8、 2の画像 2
    • Carefully slide the Jimmy through all corners of the plastic frame until it is detached from the plastic cover.
  9. Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 9、 2の画像 1 Canon EOS 60D Rear LCD screen protective plastic cover Replacement: 手順 9、 2の画像 2
    • Using your hand, lift the detached plastic cover off the plastic frame.
    • To place a new plastic cover, simply stick it to the frame in the appropriate position.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nazmi Bargouthi
メンバー登録日: 08/26/15
591 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G6
3 メンバー
14のガイドは作成済み
2 件のコメント
I followed all the steps and was able to dis- and reassamble everything in under 30min. When you reassamble make sure that in step 4 the metalplate of the housing is turned correctly and the connector is in the right position. Both could be turned 180° and mounted incorrectly. Other than that easy repair.
Thanks guys
Oliver Stietz - 返信
Hi there, can anyone send me some amazon link so I can order the correct glass? Thanks so far.
Claudio Dantas - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 2,128
