はじめに
The rear LCD screen's plastic cover provides protection for the sensitive LCD screen beneath it. If the cover is scratched or damaged, it would obstruct the display of the screen. The replacement of the plastic cover should be handled with care in order to avoid damaging the plastic frame which holds it.
必要な工具と部品
Take the LCD out of its place to expose the Phillips #PH00 screws.
Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
Slowly insert the tip of the Jimmy between the damaged plastic cover and the plastic frame, which holds it, to loosen the connection between them.
2 の人々がこのガイドを完成させました。
2 件のコメント
I followed all the steps and was able to dis- and reassamble everything in under 30min. When you reassamble make sure that in step 4 the metalplate of the housing is turned correctly and the connector is in the right position. Both could be turned 180° and mounted incorrectly. Other than that easy repair.
Thanks guys
Hi there, can anyone send me some amazon link so I can order the correct glass? Thanks so far.
