この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you drop your camera and crack or damage your screen, this guide will help you replace it.
When performing this replacement please remember that the screws you will be removing are very small. Keep them organized as you take them off and find a magnetic holder to put them in. Good luck!
必要な工具と部品
Take the LCD out of its place to expose the Phillips #PH00 screws.
Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
2 の人々がこのガイドを完成させました。
