はじめに
If the LCD swivel stops turning, or is broken by the user, this guide will help you replace it. Special care should be taken when disconnecting the LCD connector from the motherboard.
必要な工具と部品
Take the LCD out of its place to expose the Phillips #PH00 screws.
Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
Turn the swivel around to expose the remaining of the aforementioned screws.
Then use the PH00 screw driver to remove them.
Carefully pry off the LCD screen connector up from the motherboard to disconnect it, using the plastic opening tool.
4 の人々がこのガイドを完成させました。
2件のガイドコメント
anybody know how to fix the conection that make the screen turn upside down?
yoeldiamante - 返信 共有
thank you for the tutorial. but it is so wrong, there is no way to reasambly following the steps backward. do it for your self and you will see. there are skipping steps in the disassembly. carefoul anybody who follow this tutorial. i got lost in the reasambly. hope to can figure it out.
