はじめに
This is fairly straight forward, and something you may do in the normal use of your camera. It is even in the manual.
Removing the eyepiece is easy.  There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off. Grip the eyepiece by the sides firmly (index finger and thumb).  Wiggle it upwards until it is off.
  • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
  • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
コメントを追加する
Open the battery door Rotate the door so the one side of the hinge pops out (see photo #2)
  • Open the battery door
  • Rotate the door so the one side of the hinge pops out (see photo #2)
  • Slide other pin out (it pops out the same, but this is easier)
コメントを追加する
まとめ
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4 の人々がこのガイドを完成させました。
Eric D
メンバー登録日: 2012年11月13日
1,026 ポイント
5のガイドは作成済み
コメント1件
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 4,629
