はじめに
Follow this guide to replace the LCD.
必要な工具と部品
Remove both 5.4 mm screws using a Phillips #0.
I just accidentally stripped one of those screws. Is there anything I can do or am I...screwed?
Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
10 の人々がこのガイドを完成させました。
5 件のコメント
Step 8: Missing indication to remove also the third screw on the left, just next to the connector cover
where can get the lcd screen? thanks for the guide!!
Big thank you! This walkthrough really helped ;) fortunatelly only one of the connecting cables slided out of the socket that caused the lcd dead. Cam is back in business in 15 minutes ;)
Also....the last step should mention unclipping the ribbon cables in the same manner as before from the small circuit board that resides on the rear of the LCD, and the LCD has a metal frame that will need to be removed and installed on the replacement LCD before installing it. It is held in place via strong double sided tape. A little heat may need to be applied to separate it.
