メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon EOS 40D Date and Time Battery Replacement
必要な工具と部品
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: 手順 2、 1の画像 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: 手順 3、 1の画像 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 手順 4、 3の画像 1 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 手順 4、 3の画像 2 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 手順 4、 3の画像 3
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: 手順 5、 1の画像 1
    • Remove the date and time battery from the battery holder.
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Doug Kruse
メンバー登録日: 09/03/15
788 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S12G3
4 メンバー
16のガイドは作成済み
6件のガイドコメント
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - 返信 共有
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - 返信 共有
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - 返信 共有
Great help! Accurate, easy to follow directions
Jack Applegate - 返信 共有
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 34
過去 30 日: 132
今までの合計 17,472
