メインコンテンツにスキップ
Canon EOS 20D CF card slot repair
必要な工具と部品
  1. Canon EOS 20D CF card slot repair, Remove the eyepiece cap: 手順 1、 2の画像 1 Canon EOS 20D CF card slot repair, Remove the eyepiece cap: 手順 1、 2の画像 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D CF card slot repair, Remove screws from under the eyepiece cap: 手順 2、 1の画像 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D CF card slot repair, Remove hidden screw and other visible screw: 手順 3、 3の画像 1 Canon EOS 20D CF card slot repair, Remove hidden screw and other visible screw: 手順 3、 3の画像 2 Canon EOS 20D CF card slot repair, Remove hidden screw and other visible screw: 手順 3、 3の画像 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D CF card slot repair, Remove bottom screws: 手順 4、 1の画像 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D CF card slot repair, Lift and remove the rear panel: 手順 5、 3の画像 1 Canon EOS 20D CF card slot repair, Lift and remove the rear panel: 手順 5、 3の画像 2 Canon EOS 20D CF card slot repair, Lift and remove the rear panel: 手順 5、 3の画像 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D CF card slot repair, Disconnect all the labeled cables: 手順 6、 3の画像 1 Canon EOS 20D CF card slot repair, Disconnect all the labeled cables: 手順 6、 3の画像 2 Canon EOS 20D CF card slot repair, Disconnect all the labeled cables: 手順 6、 3の画像 3
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D CF card slot repair, Remove the secondary control board: 手順 7、 2の画像 1 Canon EOS 20D CF card slot repair, Remove the secondary control board: 手順 7、 2の画像 2
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
  8. Canon EOS 20D CF card slot repair, CF Card Slot: 手順 8、 3の画像 1 Canon EOS 20D CF card slot repair, CF Card Slot: 手順 8、 3の画像 2 Canon EOS 20D CF card slot repair, CF Card Slot: 手順 8、 3の画像 3
    • Open the connector for the CF slot.
    • Remove the screw that attaches the bottom of the CF slot.
    • Remove the two last screws attaching the top of the CF slot.
    • Remove the CF slot.
  9. Canon EOS 20D CF card slot repair, Attempt to rebend bent pins: 手順 9、 3の画像 1 Canon EOS 20D CF card slot repair, Attempt to rebend bent pins: 手順 9、 3の画像 2 Canon EOS 20D CF card slot repair, Attempt to rebend bent pins: 手順 9、 3の画像 3
    • This is one of several issues with this CF connector. This pin is severely bent.
    • When the pin is bent this badly, it's very likely that it will snap when you try to rebend it. There's no harm in attempting to carefully bend it back though.
  10. Canon EOS 20D CF card slot repair, Replace damaged pins: 手順 10、 2の画像 1 Canon EOS 20D CF card slot repair, Replace damaged pins: 手順 10、 2の画像 2
    • I was able to relatively easily replace the pin that snapped with a section of solid-core wire from an ethernet cable.
    • The pin I replaced here is supposed to be longer than its neighbors. This is one of the extended pins on the connector.
    • Working on the next steps will be much easier if you remove the metal shield that is attached to the CF slot by clips. I forgot to include this in the guide photos.
  11. Canon EOS 20D CF card slot repair, Fix damage from pins that got pushed in: 手順 11、 3の画像 1 Canon EOS 20D CF card slot repair, Fix damage from pins that got pushed in: 手順 11、 3の画像 2 Canon EOS 20D CF card slot repair, Fix damage from pins that got pushed in: 手順 11、 3の画像 3
    • Some pins had gotten pushed in far enough that they ripped up traces, so it was necessary to reroute their connections from the bottom vias.
    • To be able to solder to the vias, you have to scratch the solder mask off of them with a sharp tool like an Xacto knife.
    • Then it can finally be soldered to with a high gauge wire. I took a section of larger stranded-core wire, cut it, and unwound it.
    • Taping the connector down to your work surface makes it easier to work on the small solder joints required here.
  12. Canon EOS 20D CF card slot repair, Extra pin fixing tips: 手順 12、 3の画像 1 Canon EOS 20D CF card slot repair, Extra pin fixing tips: 手順 12、 3の画像 2 Canon EOS 20D CF card slot repair, Extra pin fixing tips: 手順 12、 3の画像 3
    • This is one of the cases in which I was able to reuse a pin that was broken internally but not externally, simply by pushing it back into place and running a wire from the piece left inside.
    • When soldering to the vias, note that from the rear (the area where all the pin connections are soldered to), the two pin connections on the far right and far left are ground, and don't connect down to these vias.
    • Make sure not to leave large lumps of protruding solder like the one here. I ended up having to slim it down, since it touched the metal housing of the connector when I put it back together.
    • Hopefully when you reassemble your EOS 20D, you won't be getting the "Err CF" message anymore.
終わりに
To reassemble your device, follow the disassembly instructions in reverse order.
作成者
1人の作成者と共同作成されました。
Alec M
メンバー登録日: 05/08/16
1,282 ポイント
5のガイドは作成済み
6 件のコメント
Thanks! I’m glad you found it helpful!
Let me know if you have any questions about repairing the 20D :)
Alec M - 返信
i have a problem, when my pin memory broken, just one pin, and the line almost completely removed, pleas help me
alfiandhy aziz firdaus - 返信
Hi!
What exactly is your problem? It sounds like you’re saying that the pin is broken. What does “the line is almost completely removed” exactly mean though? If it’s a broken trace on the top side, don’t worry, you can run wires from the vias on the opposite side to fix that.
Alec M -
really good job, thank you
Per Renno Blaaberg
Per Blaaberg - 返信
You’re welcome! I’m glad the guide helped you out :)
Alec M -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 16
過去 30 日: 58
今までの合計 3,226
