メインコンテンツにスキップ
Canon ELPH Z3 Camera Rear Screen Replacement
必要な工具と部品
  1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 手順 1、 3の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 手順 1、 3の画像 2 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 手順 1、 3の画像 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Rear Screen Replacement: 手順 2、 3の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 2、 3の画像 2 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 2、 3の画像 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Rear Screen Replacement: 手順 3、 2の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 3、 2の画像 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Rear Screen Replacement: 手順 4、 3の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 4、 3の画像 2 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 4、 3の画像 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: 手順 5、 2の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: 手順 5、 2の画像 2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Rear Screen Replacement: 手順 6、 3の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 6、 3の画像 2 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 6、 3の画像 3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Rear Screen Replacement: 手順 7、 2の画像 1 Canon ELPH Z3 Camera Rear Screen Replacement: 手順 7、 2の画像 2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
終わりに
作成者
2人の作成者と共同で作成されました。
Katy Skillings
メンバー登録日: 10/21/16
1 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 223
