はじめに
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
- Carefully rip out the foam that's glued onto the cover.
- Glue in the replacement document mat.
必要な工具と部品
もう少しです!
To reassemble your device, ensure that the white document mat is firmly glued on.
終わりに
ある他の人がこのガイドを完成しました。
