はじめに
If you're encountering issues as a result from the scanner bed, this is where you will want to start.
To replace the glass scanner bed, you must:
- Remove the two plastic bars that holds the scanner bed in place.
- Carefully remove the glass scanner bed to add the replacement.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
