メインコンテンツにスキップ
はじめに
This guide will teach the user how to remove a damaged SLR lens mount on the Cannon AE-1. The SLR lens mount allows the user to connect different lens to the Canon AE-1.
パーツ
パーツは指定されていません。
  1. Remove the first set of two #00 phillips screws from the lens outer casing The first set of screws are located on the front and bottom of the lens casing
    • Remove the first set of two #00 phillips screws from the lens outer casing
    • The first set of screws are located on the front and bottom of the lens casing
    • Pull the screws out and set them aside so as not to lose them
  2. Remove the remaining two #00 phillip screws from the lens outer casing The second set is located left and right side of the lens casing
    • Remove the remaining two #00 phillip screws from the lens outer casing
    • The second set is located left and right side of the lens casing
  3. Once the screws have been taken out, you may simply remove the lens casing by pulling it away from the body of the camera.
    • Once the screws have been taken out, you may simply remove the lens casing by pulling it away from the body of the camera.
  4. Remove the four #00 phillips screws from the SLR Lens Mount
    • Remove the four #00 phillips screws from the SLR Lens Mount
  5. After the screws have been removed, pull the SLR Lens Mount away from the body of the camera Be aware that a pin will fall out when the SLR Lens Mount is removed. Be aware that a pin will fall out when the SLR Lens Mount is removed.
    • After the screws have been removed, pull the SLR Lens Mount away from the body of the camera
    • Be aware that a pin will fall out when the SLR Lens Mount is removed.
終わりに
6 の人々がこのガイドを完成させました。
Joe Blumberg
メンバー登録日: 2011年10月04日
213 ポイント
1ガイドが承認済み
チーム
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011人のメンバー
UWSTOUT-ZHOU-F11S5G1
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 61
今までの合計 9,810
