はじめに
We are removing the old light filter foam and replacing it with new foam in your Canon AE-1. This will help keep light out of the inner case so that it doesn't wreck the film.
必要な工具と部品
Open the film compartment by pulling on the release pin.
Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
Then use Isopropyl Alcohol to assist in removing the old light filter foam.
もう少しです!
To reassemble your device, follow these instructions.
終わりに
2 の人々がこのガイドを完成させました。
