はじめに
This guide will show you how to remove the plastic frame from the case and how to remove the scanner glass to be replaced. A little force will be necessary but with care, this guide will be fairly easy.
必要な工具と部品
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
3 の人々がこのガイドを完成させました。
3 件のコメント
Can we replace any ordinary glass ? R there are any specifications for glass quality/type ?
