はじめに
This guide will show you how to remove the plastic frame from the case and how to remove the scanner glass to be replaced. A little force will be necessary but with care, this guide will be fairly easy.
パーツ
パーツは必要ありません。
  1. Slide the plastic opening tool under the plastic to unpeel it from the glass. Gently pry the plastic framing from the glass. Repeat on the other side.
    • Slide the plastic opening tool under the plastic to unpeel it from the glass.
    • Gently pry the plastic framing from the glass.
    • Repeat on the other side.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the front plastic frame. Remove the front plastic frame.
    • Remove the front plastic frame.
  4. Wedge the plastic opening tool under the glass and pull up. Slide the glass forward. Remove the glass.
    • Wedge the plastic opening tool under the glass and pull up.
    • Slide the glass forward.
    • Remove the glass.
まとめ
2 の人々がこのガイドを完成させました。
Shannon
メンバー登録日: 2013年10月28日
340 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-89, Diaz Fall 2013 Clemson, Team 1-89, Diaz Fall 2013人のメンバー
CLEM-DIAZ-F13S1G89
1 メンバー
2のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 893
