メインコンテンツにスキップ
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
必要な工具と部品
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 手順 1、 2の画像 1 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 手順 1、 2の画像 2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: 手順 2、 1の画像 1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 3、 1の画像 1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 4、 1の画像 1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 5、 1の画像 1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 6、 1の画像 1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 7、 1の画像 1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 8、 1の画像 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 9、 1の画像 1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: 手順 10、 1の画像 1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 11、 1の画像 1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 12、 2の画像 1 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 手順 12、 2の画像 2
    • Desolder the wires that connect the LED to the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Farshad Mohebban
メンバー登録日: 02/10/16
524 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016人のメンバー
USFT-NANCE-S16S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 1,884
