メインコンテンツにスキップ
はじめに
This guide describes the steps necessary to replace the motherboard of the system. This board contains the circuitry for the amplification, power, and output.
  1. Remove 2 screws from each side of the amplifier.
    • Remove 2 screws from each side of the amplifier.
  2. Remove 2 screws on rear of device. Slide top cover up and back from main case.
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Remove 3 screws on bottom of case. Remove 13 screws on rear panel.
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Unscrew ground wire from main case. De solder 4 wires coming from transformer.
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
終わりに
ある他の人がこのガイドを完成しました。
Colby
メンバー登録日: 2010年04月15日
284 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G36
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 5,890
