メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
必要な工具と部品
    1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: 手順 1、 2の画像 1 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: 手順 1、 2の画像 2
      • The cabin air filter is located in the passenger side footwell
      FixBotに聞いてみる
      コメントを追加
    2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 手順 2、 3の画像 1 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 手順 2、 3の画像 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 手順 2、 3の画像 3
      • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
      • Once that the screws are removed, the cover will come down.
      FixBotに聞いてみる
      コメントを追加
    3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 手順 3、 3の画像 1 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 手順 3、 3の画像 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 手順 3、 3の画像 3
      • Now with more room to remove it, slide the two plastic tabs together.
      • When the two plastic tabs are in the middle pull the filter cover down.
      FixBotに聞いてみる
      コメントを追加
    4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: 手順 4、 2の画像 1 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: 手順 4、 2の画像 2
      • Remove the filter.
      • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
      FixBotに聞いてみる
      コメントを追加
    5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: 手順 5、 1の画像 1
      • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
      • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
8 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
es en
100%
WhoDat?さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Jonatan M
メンバー登録日: 03/17/18
756 ポイント
2のガイドは作成済み
1件のガイドコメント
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - 返信 共有
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 44
過去 30 日: 261
今までの合計 14,455
