はじめに
This tutorial shows the disassembly of the vertical mouse CSL TM137U. Reason for disassembly were broken mouse switches.
必要な工具と部品
Only 3 of total 4 mouse feet must be removed for loosing the screws
Maybe heat the mouse feet to soften the adhesive for example with a hairdryer
Slide an opening pick under both the mouse feet and the adhesive underneath it.
If everything works well you can peel of the mouse feet with the adhesive and can reuse it later
The lower part has on the left side a plastic clip.
Hold the lower part in place and lift the upper part of the mouse some millimeters.
The two parts are now separated. Only the flat ribbon calbe holds both together.
Lay the upper part right next to the lower part on the table.
Lift with the flat side of a spudger the connector from the left and right side until you can easy unplug.
Unplug the connector.
Search for the two plastic clips of the click upper part. The first one you can see easily. The second one is hidden under the board.
Release the first plastic clip with your fingernail for example. Press the click upper part downwards.
The plastic clip must be completely released. The plastic clip must touch the sliding face of the other side.
There should be a visible one-sided gap between upper and lower part. An opening pick should fit in the gap.
Use a thin object such as a spudger or a wooden stick to release the second plastic clip.
You have to move the stick under the flat ribbon cable and under the board until it reaches the plastic clip.
After releasing the second plastic clip the gap between the click upper part and the whole upper part can be increased. You can the remove the whole click upper part.
Fix the right half of the upper part with your right hand.
Move yo
Hier Übersetzung einfügen
Carefully lever with the flat end of a spudger the connector
All Phillips screws: Left: 2x screws for click- scrollwheel board || Middle: 1x screw for forward-back-DPI board || right: 6x screws for mounting the upper and lower parts of the case
3x mouse feet
click-scrollwheel board
scroll wheel
lower part of the mouse case
two-piece upper part of the mouse case
Reverse the steps to reassemble your device.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
