はじめに
This guide will go over how to install O-rings on the backspace, spacebar, shift, and enter keys on your keyboard.
  1. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide.
  2. Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap.
    • Remove the plastic rings from the keycap.
  5. Place the O-rings around the nubs underneath the keycap at each circled locations. Place the O-rings around the nubs underneath the keycap at each circled locations.
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
まとめ
ある他の人がこのガイドを完成しました。
Shiva Empranthiri
メンバー登録日: 2014年10月12日
736 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G23
4 メンバー
6のガイドは作成済み
コメント1件
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,108
