はじめに
This guide will go over how to install O-rings on the backspace, spacebar, shift, and enter keys on your keyboard.
必要な工具と部品
Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide.
ある他の人がこのガイドを完成しました。
コメント 1 件
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
