メインコンテンツにスキップ
CCM Ice Skates Steel Blade Replacement
必要な工具と部品
  1. CCM Ice Skates Steel Blade Replacement, Steel Blade On CCM Skates: 手順 1、 1の画像 1
    • Place the palm of one hand over the laces at the middle of the skate boot.
    • Close that palm and firmly grasp the skate.
    • Use the other hand to grab and remove any skate guard.
  2. CCM Ice Skates Steel Blade Replacement: 手順 2、 1の画像 1
    • Place the heel/back portion of the skate on the table.
    • Firmly grasp the toe of the skate with one hand.
    • Insert the flat head screwdriver from a multi-tool into the groove of the first screw and hold.
  3. CCM Ice Skates Steel Blade Replacement: 手順 3、 1の画像 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the first screw.
    • Turn the flat head screwdriver in a counter clockwise rotation until it is loose.
  4. CCM Ice Skates Steel Blade Replacement: 手順 4、 1の画像 1
    • Remove the loosened screw from the white plastic blade holder.
    • Insert the screwdriver into the fastener and apply pressure to remove the fastener.
  5. CCM Ice Skates Steel Blade Replacement: 手順 5、 1の画像 1
    • Insert the flat head screwdriver from a multi-tool into the groove of the second screw and hold.
  6. CCM Ice Skates Steel Blade Replacement: 手順 6、 1の画像 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the second screw.
  7. CCM Ice Skates Steel Blade Replacement: 手順 7、 1の画像 1
  8. CCM Ice Skates Steel Blade Replacement: 手順 8、 1の画像 1
    • Wrap a hand in a cloth towel.
    • Pinch the two flat sides of the metal blade between the thumb and index finger.
    • Do not touch the bottom or edges of the blade.
  9. CCM Ice Skates Steel Blade Replacement: 手順 9、 1の画像 1
    • Apply pressure to the sides of the blade with your fingers.
    • Slowly pull the blade upward.
    • To avoid injury, do not pull the blade up in one quick motion.
終わりに
作成者
3人の作成者と共同で作成されました。
Steven Marcyan
メンバー登録日: 10/04/17
101 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team S5-G9, Galliah Fall 2017 Michigan Tech, Team S5-G9, Galliah Fall 2017人のメンバー
MTU-GALLIAH-F17S5G9
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 32
今までの合計 5,971
