メインコンテンツにスキップ
CCM Hardtail Mountain Bike Inner Tube Replacement
必要な工具と部品
  1. CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: 手順 1、 3の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: 手順 1、 3の画像 2 CCM Hardtail Mountain Bike Inner Tube Replacement, Inner Tube: 手順 1、 3の画像 3
    • Take the nozzle cap off to allow the tire to deflate.
    • Place the tire pump on the nozzle and press down on the nozzle.
    • You should hear a wheezing sound indicating the air is being released.
    • Squeeze the tire to check if all the air has been removed.
  2. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 2、 1の画像 1
    • Place the bike upside down so it’s resting on the handlebars.
    • Using a torque wrench with the 15mm socket, loosen the two bolts on the axle that keep the tire in place.
  3. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 4、 3の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 4、 3の画像 2 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 4、 3の画像 3
    • After removing both bolts, remove both washers that protect the frame of the bike.
    • Pull the tire in an upward motion, releasing it from the brakes and axle.
    • Insert a prying tool in between the tire and metal rim and push it outward, dislodging it from the rim and making it easier to remove.
  4. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 7、 3の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 7、 3の画像 2 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 7、 3の画像 3
    • Remove the outer tire off the rim.
    • When you remove the outer tire, the inner tube is also removed.
    • Remove the inner tube from inside of the tire.
    • Clean the inner section of the outer tire with a cloth, removing any debris.
  5. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 8、 2の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 8、 2の画像 2
    • Using the bike pump, inflate the new inner tube until it becomes circular.
    • Place the new inner tube inside the inner section of the outer tire.
  6. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 10、 3の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 10、 3の画像 2 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 10、 3の画像 3
    • Place the outer section of the tire back onto the metal rim.
    • Make sure to push the nozzle of the inner tube through the designated hole in the metal rim.
    • Begin to pull the tire onto the rim.
  7. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 11、 2の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 11、 2の画像 2
    • Place the tire back onto the axle.
  8. CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 12、 3の画像 1 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 12、 3の画像 2 CCM Hardtail Mountain Bike Inner Tube Replacement: 手順 12、 3の画像 3
    • Place the washers on both sides of the wheel.
    • Using the torque wrench and 15mm socket, tighten the bolts to the axle, making sure the tire is securely in place.
    • Using the bike pump, fill the tire with air.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ishan Ojha
メンバー登録日: 01/16/21
280 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G11, Woodhouse Winter 2021 York University, Team S1-G11, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G11
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 358
