メインコンテンツにスキップ
CASIO fx-570MS Battery Replacement
必要な工具と部品
  1. CASIO fx-570MS Battery Replacement, charger: 手順 1、 2の画像 1 CASIO fx-570MS Battery Replacement, charger: 手順 1、 2の画像 2
    • Flip the calculator over so the bottom is facing upwards.
  2. CASIO fx-570MS Battery Replacement: 手順 2、 3の画像 1 CASIO fx-570MS Battery Replacement: 手順 2、 3の画像 2 CASIO fx-570MS Battery Replacement: 手順 2、 3の画像 3
    • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
    • Remove the battery hatch.
  3. CASIO fx-570MS Battery Replacement: 手順 3、 3の画像 1 CASIO fx-570MS Battery Replacement: 手順 3、 3の画像 2 CASIO fx-570MS Battery Replacement: 手順 3、 3の画像 3
    • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
    • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
    • Caution: Be careful to not rupture the battery or damage the panel board.
  4. CASIO fx-570MS Battery Replacement: 手順 4、 3の画像 1 CASIO fx-570MS Battery Replacement: 手順 4、 3の画像 2 CASIO fx-570MS Battery Replacement: 手順 4、 3の画像 3
    • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
    • Make sure the flat side of the battery is facing upwards.
    • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
  5. CASIO fx-570MS Battery Replacement: 手順 5、 2の画像 1 CASIO fx-570MS Battery Replacement: 手順 5、 2の画像 2
    • Close the plastic hatch and secure the screw.
  6. CASIO fx-570MS Battery Replacement: 手順 6、 2の画像 1 CASIO fx-570MS Battery Replacement: 手順 6、 2の画像 2
    • Flip the calculator on its back and press the 'ON' button to power it up.
    • A zero will appear on the bottom right corner of the LED display.
終わりに
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Saquib Ahmed
メンバー登録日: 09/20/20
205 ポイント
1ガイドが承認済み
チーム
York University, Team S3-G40, Melo-Thaiss Fall 2020 York University, Team S3-G40, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S3G40
1 メンバー
5のガイドは作成済み
1件のガイドコメント
How much does the battery cost?
Tamanna - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 74
過去 30 日: 465
今までの合計 55,478
