メインコンテンツにスキップ
CASIO fx-50FH II Scientific Calculator Battery Replacement
必要な工具と部品
  1. CASIO fx-50FH II Scientific Calculator Battery Replacement, Battery: 手順 1、 1の画像 1
    • To turn the calculator off, first press the "shift" button.
    • Release the "shift" button, then press the "AC" button.
  2. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 2、 2の画像 1 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 2、 2の画像 2
    • Place the calculator face down, then use a Phillips #00 screwdriver to remove the single screw securing the battery hatch in the top right corner.
  3. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 3、 3の画像 1 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 3、 3の画像 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 3、 3の画像 3
    • Push the battery hatch to the right until it slides off.
  4. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 4、 3の画像 1 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 4、 3の画像 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 4、 3の画像 3
    • Put on a pair of protective gloves before handling the battery to eliminate the risk of chemical burns.
    • Insert the tip of a spudger into the indent on the right-hand side of the battery to lift the edge of the battery up.
    • Lift the battery up and out.
  5. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 5、 1の画像 1
    • Inspect the battery compartment any alkaline residue.
    • If no residue is present, skip to Step 7.
  6. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 6、 3の画像 1 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 6、 3の画像 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 6、 3の画像 3
    • Use a cotton swab dabbed with white vinegar to wipe the alkaline off the battery compartment.
    • Use a dry cotton swab to remove the vinegar and alkaline residues.
    • Let the battery compartment dry completely.
  7. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 7、 1の画像 1
    • Insert a new LR44 1.5V alkaline button battery into the compartment, with the positive sign facing up.
  8. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 8、 3の画像 1 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 8、 3の画像 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 8、 3の画像 3
    • Reattach the battery hatch by sliding the hatch in from the right to the left.
  9. CASIO fx-50FH II Scientific Calculator Battery Replacement: 手順 9、 1の画像 1
    • Use a Phillips #00 to secure the screw.
終わりに
You have successfully replaced the battery of  a CASIO fx-50FH II Scientific Calculator!
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Cheuk Wai Chan
メンバー登録日: 07/05/22
196 ポイント
1ガイドが承認済み
チーム
York University, Team M-4, Allen Summer 2022 York University, Team M-4, Allen Summer 2022人のメンバー
YORK-ALLEN-SU22SMG4
1 メンバー
2のガイドは作成済み
2 件のコメント
Very nice guide! I found the pictures to be very good and corresponding to the steps very well.
Frank Loi - 返信
Thank you for the steps. I followed the steps and managed to salvage my calculator which I almost had to throw away. This has helped reduce waste. :)
Nancy Yeo - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 105
今までの合計 1,794
