メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: 手順 1、 2の画像 1 C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: 手順 1、 2の画像 2
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
  2. C-Clamp Sternum Strap Replacement: 手順 2、 3の画像 1 C-Clamp Sternum Strap Replacement: 手順 2、 3の画像 2 C-Clamp Sternum Strap Replacement: 手順 2、 3の画像 3
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
  3. C-Clamp Sternum Strap Replacement: 手順 4、 2の画像 1 C-Clamp Sternum Strap Replacement: 手順 4、 2の画像 2
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
ゴール
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Zach Mueller
メンバー登録日: 02/23/23
1,762 ポイント
9のガイドは作成済み
チーム
Patagonia Patagonia人のメンバー
Community
9 メンバー
141のガイドは作成済み
2件のガイドコメント
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - 返信 共有
paul.butera - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 33
過去 30 日: 139
今までの合計 4,171
