Throughout this step, make sure you support the handle and head with at least three hands.
Slide the bearing rod out of the head.
Inspect the bearing rod and head for any wear or tear.
Firmly lift the riser main slider with two hands.
Use caution not to drop the riser main, as this can damage the pump cylinder.
Lift the slider and riser main pipe.
Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
Carefully lower the riser main and slider to allow it to rest on the rod clamp.
Remove the riser main slider, and inspect it for wear and tear.
Set the slider in a sanitary place to prevent contamination.
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
Use a pipe wrench to loosen and remove the pump spout.
Inspect the spout for obstructions or potential contaminants.
Place the spout on a clean surface to prevent any contamination.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
