はじめに
Follow this guide to remove the sections of riser main from a Bush pump. You can either remove the entire riser main for replacement, or just remove and replace or repair a broken section.
This guide uses the help of a tripod to lift the riser main. It can, alternatively, be lifted using lifting spanners, but a tripod allows the process to be done by two people. Still use caution when using a tripod.
必要な工具と部品
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Place one wrench on the top of one of the pump riser plate bolts.
Place another wrench around the bottom of the bolt.
Pull the wrenches apart to loosen the bolt.
