メインコンテンツにスキップ
Brother PT-D200 LCD Screen Replacement
必要な工具と部品
  1. Brother PT-D200 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the six AAA batteries.
  3. Brother PT-D200 LCD Screen Replacement, Back of Device: 手順 3、 1の画像 1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 LCD Screen Replacement: 手順 4、 1の画像 1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 LCD Screen Replacement, Circuit Board Cables: 手順 5、 1の画像 1
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  6. Brother PT-D200 LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  7. Brother PT-D200 LCD Screen Replacement, Circuit Board: 手順 7、 2の画像 1 Brother PT-D200 LCD Screen Replacement, Circuit Board: 手順 7、 2の画像 2
    • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
  8. Brother PT-D200 LCD Screen Replacement: 手順 8、 1の画像 1
    • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
  9. Brother PT-D200 LCD Screen Replacement: 手順 9、 1の画像 1
    • Disconnect the LCD ribbon cable from the circuit board.
  10. Brother PT-D200 LCD Screen Replacement, Face Plate: 手順 10、 1の画像 1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  11. Brother PT-D200 LCD Screen Replacement: 手順 11、 2の画像 1 Brother PT-D200 LCD Screen Replacement: 手順 11、 2の画像 2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
  12. Brother PT-D200 LCD Screen Replacement, Keyboard: 手順 12、 2の画像 1 Brother PT-D200 LCD Screen Replacement, Keyboard: 手順 12、 2の画像 2
    • Peel off the rubber keyboard of the device.
  13. Brother PT-D200 LCD Screen Replacement, LCD Screen: 手順 13、 2の画像 1 Brother PT-D200 LCD Screen Replacement, LCD Screen: 手順 13、 2の画像 2
    • Lift the LCD screen out of place.
終わりに
作成者
4人の作成者と共同で作成されました。
Jeston Mitchell
メンバー登録日: 01/24/14
308 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G16
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 1,665
