この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will walk you through the process of replacing the faceplate on a Brother PT-D200.
必要な工具と部品
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
ある他の人がこのガイドを完成しました。
