メインコンテンツにスキップ
Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: 手順 1、 2の画像 1 Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: 手順 1、 2の画像 2
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: 手順 2、 2の画像 1 Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: 手順 2、 2の画像 2
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: 手順 3、 2の画像 1 Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: 手順 3、 2の画像 2
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 Tape Cassette Replacement, Evaluating: 手順 4、 1の画像 1
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: 手順 5、 1の画像 1
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
終わりに
作成者
9人の作成者と共同で作成されました。
Lorraine Canez
メンバー登録日: 10/25/14
318 ポイント
3のガイドは作成済み
チーム
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G4
3 メンバー
6のガイドは作成済み
コメント 1 件
Wie wird die Kassette eingesetzt
Uwe Seiler - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 33
今までの合計 19,744
