メインコンテンツにスキップ
Brother PT-1290 Cutter Blade Replacement
必要な工具と部品
  1. Brother PT-1290 Cutter Blade Replacement, Removing the bottom cover of the Brother PT-1290: 手順 1、 3の画像 1 Brother PT-1290 Cutter Blade Replacement, Removing the bottom cover of the Brother PT-1290: 手順 1、 3の画像 2 Brother PT-1290 Cutter Blade Replacement, Removing the bottom cover of the Brother PT-1290: 手順 1、 3の画像 3
    • Flip the device over and locate the round part right next to the face plate. Gently but firmly, push it down. At the same time, while holding both sides of the device, split them apart carefully because some cables are attached to both sides.
    • In this step, spudger is being used only to indicate the area. No tools other than the hands will be used.
  2. Brother PT-1290 Cutter Blade Replacement, Accesing the area where the blade is located: 手順 2、 3の画像 1 Brother PT-1290 Cutter Blade Replacement, Accesing the area where the blade is located: 手順 2、 3の画像 2 Brother PT-1290 Cutter Blade Replacement, Accesing the area where the blade is located: 手順 2、 3の画像 3
    • Once the device has been split open, locate the blade, that in this particular label printer the color is yellow as is indicated in this guide.
    • Locate the area where the blade is located and get ready to start the replacing process.
  3. Brother PT-1290 Cutter Blade Replacement, Removing and replacing the cutter blade: 手順 3、 3の画像 1 Brother PT-1290 Cutter Blade Replacement, Removing and replacing the cutter blade: 手順 3、 3の画像 2 Brother PT-1290 Cutter Blade Replacement, Removing and replacing the cutter blade: 手順 3、 3の画像 3
    • Release the blade by pushing it with the spudger and have the replacement ready to install.
    • Avoid touching the blade for safety reasons, even though is not sharp enough to cut the label, it can cut through your skin.
  4. Brother PT-1290 Cutter Blade Replacement, Putting the pieces back together: 手順 4、 3の画像 1 Brother PT-1290 Cutter Blade Replacement, Putting the pieces back together: 手順 4、 3の画像 2 Brother PT-1290 Cutter Blade Replacement, Putting the pieces back together: 手順 4、 3の画像 3
    • After replacing the cutter blade, you want to make sure the bottom cover is placed correctly and the two pins that lock the cover are aligned first. These pins are not a problem at the beginning while opening the cover, because they split open right away. However, you have to be careful when closing it to avoid any damage.
    • Happy fix it and after finishing the assembly...be proud of yourself!
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Yadira Jones
メンバー登録日: 10/25/14
273 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 26
今までの合計 2,677
