メインコンテンツにスキップ
Brother PT-110 Print Roller Lever Replacement
必要な工具と部品
  1. Brother PT-110 Print Roller Lever Replacement, Batteries: 手順 1、 2の画像 1 Brother PT-110 Print Roller Lever Replacement, Batteries: 手順 1、 2の画像 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Print Roller Lever Replacement: 手順 2、 1の画像 1
    • Remove the batteries.
  3. Brother PT-110 Print Roller Lever Replacement, Back Plate: 手順 3、 2の画像 1 Brother PT-110 Print Roller Lever Replacement, Back Plate: 手順 3、 2の画像 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Print Roller Lever Replacement: 手順 4、 1の画像 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Print Roller Lever Replacement: 手順 5、 1の画像 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Print Roller Lever Replacement: 手順 6、 1の画像 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Print Roller Lever Replacement: 手順 7、 2の画像 1 Brother PT-110 Print Roller Lever Replacement: 手順 7、 2の画像 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Print Roller Lever Replacement: 手順 8、 3の画像 1 Brother PT-110 Print Roller Lever Replacement: 手順 8、 3の画像 2 Brother PT-110 Print Roller Lever Replacement: 手順 8、 3の画像 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Print Roller Lever Replacement, Print Roller Lever: 手順 9、 1の画像 1
    • Using the metal spudger, swivel the pin so that the print roller lever loosens.
  10. Brother PT-110 Print Roller Lever Replacement: 手順 10、 1の画像 1
    • Gently pull the print roller lever out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kimberly Larsen
メンバー登録日: 09/28/16
237 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016人のメンバー
IUPUI-HARLEY-F16S1G1
3 メンバー
7のガイドは作成済み
5 件のコメント
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Daniel Verkest - 返信
BONJOUR, (I’m French)
Same question: does anyone knows were I can by such a lever ?
Pegase M - 返信
Did anyone find a source for this part?
Erik Carlson - 返信
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
Michael Krieger - 返信
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
George Pede - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 28
今までの合計 1,661
