メインコンテンツにスキップ
Brother PT-1010 Keyboard Replacement
必要な工具と部品
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: 手順 1、 1の画像 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: 手順 3、 1の画像 1
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: 手順 4、 1の画像 1
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: 手順 5、 1の画像 1
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 手順 6、 3の画像 1 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 手順 6、 3の画像 2 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: 手順 6、 3の画像 3
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: 手順 7、 1の画像 1
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: 手順 8、 1の画像 1
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 手順 9、 3の画像 1 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 手順 9、 3の画像 2 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: 手順 9、 3の画像 3
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Haley Sweet
メンバー登録日: 10/30/14
460 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G4
4 メンバー
4のガイドは作成済み
3 件のコメント
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - 返信
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - 返信
Screen is dull, what to do
Judy Baranczyk - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 3,064
