メインコンテンツにスキップ
Brother PT-1010 Cassette Tape Replacement
必要な工具と部品
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: 手順 1、 1の画像 1
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: 手順 2、 1の画像 1
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
終わりに
作成者
1人の作成者と共同作成されました。
Haley Sweet
メンバー登録日: 10/30/14
460 ポイント
4のガイドは作成済み
チーム
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G4
4 メンバー
4のガイドは作成済み
3 件のコメント
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - 返信
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - 返信
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 3,247
