メインコンテンツにスキップ
Brother MFC-9130CW Ink Cartridge Replacement
必要な工具と部品
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: 手順 1、 1の画像 1
    • Press the power button on the printer for a couple of seconds to turn it off.
  2. Brother MFC-9130CW Ink Cartridge Replacement: 手順 2、 2の画像 1 Brother MFC-9130CW Ink Cartridge Replacement: 手順 2、 2の画像 2
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
  3. Brother MFC-9130CW Ink Cartridge Replacement: 手順 3、 1の画像 1
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
  4. Brother MFC-9130CW Ink Cartridge Replacement: 手順 4、 2の画像 1 Brother MFC-9130CW Ink Cartridge Replacement: 手順 4、 2の画像 2
    • Pull each ink cartridge tray out of its slot using the center handle.
  5. Brother MFC-9130CW Ink Cartridge Replacement: 手順 5、 2の画像 1 Brother MFC-9130CW Ink Cartridge Replacement: 手順 5、 2の画像 2
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
  6. Brother MFC-9130CW Ink Cartridge Replacement: 手順 6、 2の画像 1 Brother MFC-9130CW Ink Cartridge Replacement: 手順 6、 2の画像 2
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
  7. Brother MFC-9130CW Ink Cartridge Replacement: 手順 7、 3の画像 1 Brother MFC-9130CW Ink Cartridge Replacement: 手順 7、 3の画像 2 Brother MFC-9130CW Ink Cartridge Replacement: 手順 7、 3の画像 3
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
  8. Brother MFC-9130CW Ink Cartridge Replacement: 手順 8、 1の画像 1
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
終わりに
To reassemble your device, follow these instructions in the given order.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kamaljot
メンバー登録日: 01/08/24
184 ポイント
1ガイドが承認済み
チーム
York University, Team 2-28, O'Regan Winter 2024 York University, Team 2-28, O'Regan Winter 2024人のメンバー
YORK-O'REGAN-W24S2G28
1 メンバー
2のガイドは作成済み
1件のガイドコメント
One step is missing : release the orange cover.
Artefil - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 49
今までの合計 561
