はじめに
Many functions, including the LCD screen dial pad and device functions can wear and no longer work and may need to be replaced.
ツール
パーツ
パーツは指定されていません。
Unscrew these three 12.1mm screws holding the control panel in place.
Lift up the front panel from the device.
Gently lift up and pull out the data cables that attach the panel to the printer.
To reassemble the front panel, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
コメント1件
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
