メインコンテンツにスキップ
Brother CE8080 Bobbin Replacement
必要な工具と部品
  1. Brother CE8080 Bobbin Replacement, Bobbin: 手順 1、 1の画像 1
    • Make sure that the presser foot (the part that holds fabric in place) is in the raised position before removing the bobbin cover.
    • Lift the bobbin cover case found beneath the needle.
  2. Brother CE8080 Bobbin Replacement: 手順 2、 1の画像 1
    • Pull the defective bobbin out of the bobbin case and dispose of it properly.
    • Empty the thread from the defective bobbin before disposing of it so you can use the excess thread.
  3. Brother CE8080 Bobbin Replacement: 手順 3、 2の画像 1 Brother CE8080 Bobbin Replacement: 手順 3、 2の画像 2
    • Take the new bobbin and place it inside the bobbin case.
    • Pull at least two inches of thread from the end of the bobbin so you're able to access it and it doesn't get tangled.
  4. Brother CE8080 Bobbin Replacement: 手順 4、 1の画像 1
    • Pull the thread at the end of the bobbin that's sticking out from the base of the machine.
  5. Brother CE8080 Bobbin Replacement: 手順 5、 3の画像 1 Brother CE8080 Bobbin Replacement: 手順 5、 3の画像 2 Brother CE8080 Bobbin Replacement: 手順 5、 3の画像 3
    • Insert the thread carefully to the tension-adjusting spring of the bobbin case.
    • The Brother CE8080 has a built-in arrow guide that shows you where to insert the thread.
  6. Brother CE8080 Bobbin Replacement: 手順 6、 1の画像 1
    • Cut off excess thread using fabric scissors.
    • Make sure to cut the end of the thread at a slanted angle to prevent thread breakage.
  7. Brother CE8080 Bobbin Replacement: 手順 7、 1の画像 1
    • Place the bobbin cover back in its original position on the sewing machine.
    • Make sure it "clicks" when placing the bobbin cover back. The click sound ensures that the cover is locked.
終わりに
作成者
1人の作成者と共同作成されました。
LOU ERIKA U MUEGA
メンバー登録日: 07/03/22
145 ポイント
1ガイドが承認済み
チーム
York University, Team M-16, Allen Summer 2022 York University, Team M-16, Allen Summer 2022人のメンバー
YORK-ALLEN-SU22SMG16
1 メンバー
1のガイドは作成済み
2 件のコメント
I found your guide straightforward to read and understand, and it is typically adequate. In my opinion, the presence of clear images and the marker you used in the first picture will help and enable readers to repair their sewing machine easily. Well done!
Rami Yamout - 返信
Excellent illustration!!!
KO SAMUEL TAK SHUN - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 30
今までの合計 887
