メインコンテンツにスキップ
Brother Boutique 761 Needle Replacement
必要な工具と部品
  1. Brother Boutique 761 Needle Replacement, Needle: 手順 1、 2の画像 1 Brother Boutique 761 Needle Replacement, Needle: 手順 1、 2の画像 2
    • Locate the screw and turn the screw counterclockwise (left).
    • Loosen the screw gently and carefully remove the needle.
  2. Brother Boutique 761 Needle Replacement: 手順 2、 1の画像 1
    • Remove the faulty needle and replace it with a new needle.
  3. Brother Boutique 761 Needle Replacement: 手順 3、 1の画像 1
    • Take the new needle, place the needle carefully at the base of the opening.
    • Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
  4. Brother Boutique 761 Needle Replacement: 手順 4、 2の画像 1 Brother Boutique 761 Needle Replacement: 手順 4、 2の画像 2
    • Secure the needle once again. We will start to re-thread the sewing machine.
    • Place the thread on the lever with the loose piece of thread on the outside.
  5. Brother Boutique 761 Needle Replacement: 手順 5、 1の画像 1
    • Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
  6. Brother Boutique 761 Needle Replacement: 手順 6、 1の画像 1
    • Pull the thread down towards you in the open on the front of your machine.
    • Hook the thread at the end of the opening.
  7. Brother Boutique 761 Needle Replacement: 手順 7、 1の画像 1
    • Take your thread and locate the hole that is in the needle.
    • Put the thread through the hole.
  8. Brother Boutique 761 Needle Replacement: 手順 8、 1の画像 1
    • Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
    • You have now finished replacing the needle and rethreading the sewing machine.
終わりに
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
作成者
2人の作成者と共同で作成されました。
Erin Juarez
メンバー登録日: 10/23/23
157 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 1-6, Bennett Fall 2023 Sam Houston State, Team 1-6, Bennett Fall 2023人のメンバー
SHSU-BENNETT-F23S1G6
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 336
