メインコンテンツにスキップ
Broken Zipper On Luggage Replacement
必要な工具と部品
  1. Broken Zipper On Luggage Replacement, Zipper: 手順 1、 1の画像 1
    • Remove the metal stopper at the end with the pliers (which ever set works for your size zipper), using a bit of pressure to pry it off of the slider. This will help the current, broken zipper come off easier.
  2. Broken Zipper On Luggage Replacement: 手順 2、 1の画像 1
    • Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers. Apply pressure vertically to pry the zipper away from the teeth of the slider.
    • Use the other pair of pliers to keep the zipper in place while you remove it. It should then smoothly slide off of the slider.
  3. Broken Zipper On Luggage Replacement: 手順 3、 1の画像 1
    • Install the new zipper. To do this, simply slide the new zipper over the end of the slider chain in the same direction than the old one. This should secure the teeth together for a comfortable fit.
  4. Broken Zipper On Luggage Replacement: 手順 4、 1の画像 1
    • Applying pressure, use pliers to reattach the metal zipper stopper.
  5. Broken Zipper On Luggage Replacement: 手順 5、 1の画像 1
    • Secure the new zipper, using the pliers, setting the stoppers back in place and molding it back together.
終わりに
Mold and bend the stopper, using the pliers, to set the stopper back in place.
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ashley Cooper
メンバー登録日: 01/19/18
220 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018人のメンバー
USFSM-STEWART-S18S1G1
15 メンバー
25のガイドは作成済み
4 件のコメント
Thank you. I am about to try this. A few suggestions— you say we need a screwdriver but don’t actually describe using it. It would helpful to identify the three parts of the zipper— the pull , the slider train and the stop—right at the beginning, and be consistent throughout.
aurora - 返信
Thanks for trying to help but you seem to miss out all the critical (difficult) steps. I have read the guide and still have no better idea of what to do.
Simon Bird - 返信
what is a slider chain?
Janet Angelo - 返信
These recommendations are completely incomprehensible. I recommend a visit to the Zipper Rescue website.
David Hammel - 返信
コメントを追加
統計データ:
過去 24時間: 128
過去 7 日: 913
過去 30 日: 3,841
今までの合計 122,868
