メインコンテンツにスキップ
Briggs and Stratton 675 Series Spark Plug Replacement
必要な工具と部品
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 手順 1、 2の画像 1 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 手順 1、 2の画像 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 手順 2、 3の画像 1 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 手順 2、 3の画像 2 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 手順 2、 3の画像 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Saunders
メンバー登録日: 02/01/15
948 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G31
4 メンバー
13のガイドは作成済み
12 件のコメント
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 返信
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 返信
pinch the front of black cap and pull off
tracy.mullen - 返信
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - 返信
Kymberleah - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 62
過去 30 日: 231
今までの合計 46,437
