この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Follow these steps to remove the muffler from your engine. Once removed, a damaged muffler can be replaced or a dirty one cleaned. The muffler can become dirty or damaged over time. It is important to keep it clear of debris so that the exhaust coming from the engine can flow normally. Once removed, a damaged muffler can be replaced or a dirty one cleaned.
必要な工具と部品
Use a socket wrench with a 1/4" hex bit or a 1/4" wrench to remove the three 13mm screws holding the outer flange.
Remove the flange.
ある他の人がこのガイドを完成しました。
