このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Wipe any oil off the tip of the stick and reinsert it into the mower. Make sure to tighten the cap down when doing so.
Remove the cap and stick once again and note the height of the oil left on the bottom of the stick.
If the oil is in between the two small holes, looks clean, and you haven't experienced any mechanical difficulties, your mower's oil is in good shape and does not need replacement.
5 の人々がこのガイドを完成させました。
8 件のコメント
how much oil is recommended for this engine?
Will Irvin - 返信
this guide is wrong. to change oil you have a bolt bottom, never empty oil on that method.
What is the oil capacity of this engine, and what grade of oil is recommended ?
Thus engine is on a 22 ton log splitter and there is no way of tipping engine over to change oil.
rich burke - 返信
