メインコンテンツにスキップ
Briggs and Stratton 675 Series Oil Replacement
必要な工具と部品
  1. Briggs and Stratton 675 Series Oil Replacement, Oil: 手順 1、 1の画像 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • The oil tank cap is on the top right of the engine.
    • Remove the cap by turning it a quarter turn to the left and lifting up.
    • The cap will be attached to a long metal stick.
  2. Briggs and Stratton 675 Series Oil Replacement: 手順 2、 2の画像 1 Briggs and Stratton 675 Series Oil Replacement: 手順 2、 2の画像 2
    • Before continuing, take note of your current oil level by following these steps.
    • The metal rod attached to the cap is the dip stick and is used to test the oil level in your mower.
    • Wipe any oil off the tip of the stick and reinsert it into the mower. Make sure to tighten the cap down when doing so.
    • Remove the cap and stick once again and note the height of the oil left on the bottom of the stick.
    • If the oil is in between the two small holes, looks clean, and you haven't experienced any mechanical difficulties, your mower's oil is in good shape and does not need replacement.
  3. Briggs and Stratton 675 Series Oil Replacement: 手順 3、 1の画像 1
    • Check to make sure there is no fuel in the tank before removing the oil.
    • To remove the oil, tilt the mower on its side and pour the old oil into a proper container.
    • Alternatively, you can use a siphon/pump down the opening to remove the oil.
    • Never pour engine oil down the sink. Put it in a sealed container and take it to a proper oil recycling or waste disposal facility.
    • If using the tilt and pour method, ensure there is no fuel in the tank, as it may leak out.
    There was a drain bolt at bottom of the sump on my 675-powered high pressure washer. Square socket extension fit it perfectly.
    TIP: If you can, run the engine enough to get it warm so the 30 wt oil flows more freely when you are draining it. Mine seemed to take about a pint.
    Bob - 返信
  4. Briggs and Stratton 675 Series Oil Replacement: 手順 4、 2の画像 1 Briggs and Stratton 675 Series Oil Replacement: 手順 4、 2の画像 2
    • Once all the oil is drained from your mower, tilt everything right-side-up and refill the engine with oil by pouring directly into the hole.
    • Insert the cap back onto the hole and tighten to close.
    • It can be helpful to use a funnel to ensure that the oil does not spill over the outside of your engine. Spilled oil can be difficult to clean up.
    And how much oil?
    Pasi Virtanen - 返信
終わりに
5 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Brad Wash
メンバー登録日: 02/02/15
476 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G31
4 メンバー
14のガイドは作成済み
8 件のコメント
how much oil is recommended for this engine?
Will Irvin - 返信
this guide is wrong. to change oil you have a bolt bottom, never empty oil on that method.
Juan Pablo Vincenti - 返信
@Juan Pablo Vincenti this Motor has no bolt at the bottom I think. I have it on my mower and did not find any bolt there where it usually is (and also is at the older Briggs and Stratton motors I used in the past). So I guess you have to do it this way...
Johnny - 返信
What is the oil capacity of this engine, and what grade of oil is recommended ?
Howard Quinby - 返信
Thus engine is on a 22 ton log splitter and there is no way of tipping engine over to change oil.
rich burke - 返信
A 675 is 18 fl oz, or roughly .5 liters. The recommended type depends on some factors you can look at on this site. https://www.briggsandstratton.com/na/en_...
Blake Reeder - 返信
In my mower the bolt (imbus screw) is in the housing of the rotational cutter. So you need to lift your mower and look at it from underneath
Stefan - 返信
Briggs & Stratton claim their 675EXi engine never needs an oil change. I personally ain't buying that claim. All oil eventually degrades no matter how smooth their piston bores and cooler running their engine is. It's asinine that they do not put a bolt on the bottom to change it out so I have to tip the entire mower on it's side to drain it which means any sludge that settled to the bottom is now still in the mower when I tip it and probably won't travel out the top completely. This is planned obsolescence in design. They want you to just wear this one out instead of changing the oil.
boiledbeef - 返信
コメントを追加
統計データ:
過去 24時間: 36
過去 7 日: 317
過去 30 日: 1,593
今までの合計 71,141
